Hi guys,
any one know of a way to delete users in bulk?
I noticed that about 30 users have left our department and would like to remove them from the system, is there a quick way for me to delete them in bulk? does it have to be done through a TI? If yes, can I ask for a copy of the code?
Thanks in advance.
Gaby
Delete Users in Bulk
Re: Delete Users in Bulk
1/ Save the list of users as a plain text file;yyround wrote:Hi guys,
Thanks in advance.
Gaby
2/ Specify that file as the data source;
3/ Use the DeleteClient(ClientName); function in the Metadata tab.
TrevorGoss
- Version: 10.2.1.1
- Excel Version: 14.0.6129.5000
Alan's solution will work, but if you are authenticating via BI, it is possible for the deleted clients to "come back" so to speak, simply by logging back into the TM1 service. Provided they have the credentials (AD, for example) of course.Alan Kirk wrote:1/ Save the list of users as a plain text file;yyround wrote:Hi guys,
Thanks in advance.
Gaby
- qml
- Excel Version: 2007 - 2016
This behaviour can be easily prevented by using a config parameter available from version 10.2.2 FP5 onwards.TrevorGoss wrote:Alan's solution will work, but if you are authenticating via BI, it is possible for the deleted clients to "come back" so to speak, simply by logging back into the TM1 service. Provided they have the credentials (AD, for example) of course.
Kamil Arendt
yyround
- Version: PA2.0.8
- Excel Version: MS 2016
Thank you so much all
