Tm1RptRow - Mdx Expression with sorting on Alias
chewza
Version: 9.5
Excel Version: 7
Post by chewza »
Hi there
I have a Tm1RptRow expression with the mdx parameter.
Problem:
I need the rows returned by the Mdx to be sorted according to an ALIAS.
Using the Tm1Sort function in the mdx will sort according to the original elements - doesn't allow you to specify alias.
I know that in the Tm1RptRow function itself you can specify the alias you want to display. However, this doesn't help because I want the rows SORTED by the alias.
Any ideas?
Many thanks!
Chris
Re: Tm1RptRow - Mdx Expression with sorting on Alias
You want to use the order function as you would with any attribute type.
Below is an example; you will want to look into the differences between ASC, BASC, DESC and BDESC to get the result you want.
{Order({[DIM_NAME].members},[DIM_NAME].[ALIAS_NAME],ASC)}
chewza
Version: 9.5
Excel Version: 7
Post by chewza »
Brilliant - much appreciated!!!
