app_maintenance.bat with CAM Security-INVALID_IDENTITY
duc82000
Excel Version: Excel 2016
Post by duc82000 »
I am trying to run the app_maintenance.bat and getting an INVALID_IDENTITY error.
The things I tried to overcome this is below:
1) I looked at the previous forum and tried to manually get the CAM_Passport information needed by logging on the BI Server and the pressing F12
(http://www-01.ibm.com/support/docview.w ... wg21981075). There isn't any CAM_Passport info from doing this.
2) Also, from http://www.tm1forum.com/viewtopic.php?t=10265 and https://greenydangerous.com/2015/01/27/ ... challenge/
I tried to create a powershell script that will be saved into the text file. The powershell script ran fine but it created a text file that was empty.
Is there another way for me to try and get the CAM_Passport information to pass it to the app_maintenance.bat script?
Any help is much appreciated.
Duc
duc82000
Re: app_maintenance.bat with CAM Security-INVALID_IDENTITY
Post by duc82000 »
I was able to get the Cam_Passport parameter manually and pass it to app_maintenance script but still getting INVALID_IDENTITY.
Duc
duc82000
Post by duc82000 »
I got the script to dump the Cognos passport parameter and then passed it to the app_maintenance script. It is now working fine.
Emixam
Post by Emixam »
Anybody still using app_maintenance with CAM with the new version of TM1Web (Planning Analytics Local 2.0.55 and after) ? It stop working for us since we did the upgrade. Maybe it's because TM1 Applications (pmpsvc) is now using a different port number than TM1Web ?
This was working before (port 9510)
D:
cd "D:\Program Files\ibm\cognos\tm1_64\webapps\pmpsvc\WEB-INF\tools"
app_maintenance.bat
-serviceUrl hostName.domainName:9510/pmpsvc
-username MyUserName
-userpwd  MyPassword
-CAMNamespace MyNameSpace
-applicationid df446e27-7221-4af3-9a65-e3d63eade41
-op deactivate
This is no longer working (port 9511)
D:
app_maintenance.bat
-serviceUrl hostName.domainName:9511/pmpsvc
-userpwd  MyPassword
-op deactivate
I get the following error message:
An exception occured during operation execute:'com.ibm.cognos.fpmsvc.exception.FPMSVCException: Invalid identity string. :INVALID_IDENTITY'
 WHILE [CCLMsg: system text='INVALID_IDENTITY']
exitCode=700
Am I missing something ?
