SubsetAliasSet weird behavior
vladino
Excel Version: Excel 2013
Post by vladino »
Hi guys,
I'm getting really strange behavior of SubsetAliasSet TI function.
I have created a new dynamic subset (it doesn't matter if it's been created within TI process or manually).
Now I would like to set the alias for the subset using SubsetAliasSet.
When I use following code:
SubsetAliasSet('Dimension', 'temp', 'Alias');
I'm getting following error:
Error: Epilog procedure line (5): Subset "temp" not found in dimension "Alias"
Which is strange as the parameters of SubsetAliasSet are DimName, SubName, AliasName.
When I change the order of parameters like this:
SubsetAliasSet('Alias', 'temp', 'Dimension');
Error: Epilog procedure line (6): Subset "temp" not found in dimension "Dimension"
But I can see the subset on the dimension!
Am I doing something wrong or is it a bug?
Thanks a lot for your help!
BR
Vladino
Re: SubsetAliasSet weird behavior
Hello there,
This comes straight out of an IBM TI process:
}tp_create_planning_artifacts:
Line 423: 	SubsetAliasSet('}Groups', cTpDefaultSubset, '}TM1_DefaultDisplayValue');
So that's the syntax (and I use it a lot like this).
Are you sure that the objects exist ?
What does SubsetExists( ... ) give you ?
DimensionExists( ... ) ?
Dimix( '}ElementAttributes_Dimension', 'Alias' ) ?
Dtype( '}ElementAttributes_Dimension', 'Alias' ) ?
What if you create a new subset manually ?
Does it work on another dimension / subset / alias combination ?
Do you use localisations of dimension names ?
And so on.
Wim
vladino
Post by vladino »
Hi Wim,
Wim Gielis wrote:Are you sure that the objects exist ?
Yes, the objects exist - SubsetExists returns 1, DimensionExists also returns 1.
Dimix returns 5.
Dtype returns "AA".
Wim Gielis wrote:Does it work on another dimension / subset / alias combination ?
Yes, it seems that on other dimensions it works.
Wim Gielis wrote:Do you use localisations of dimension names ?
I just changed the "Caption" attribute for all dimensions.
This is really strange...
What about restarting the model ?
vladino
Post by vladino »
Wim Gielis wrote:What about restarting the model ?
Ahh, I forgot to use the easiest way how to fix most problems... After restarting the TM1 instance is works. :)
Thanks Wim!
