Hi Folks,
Could you please suggest any alternative tool as good as TM1 , for Budgeting and forecasting.
1) Would be awesome if proposed tool has connectivity with NO-SQL database like HBASE or MAPRDB.
or
2) Any alternative tool that provides option of storing data into No-SQL database. So finance team can load the data into No-SQL database and Machine learning can happen in parallel.
Dip.
Alternative of Cognos TM1
RJ!
Re: Alternative of Cognos TM1
Excel!
You can create your own Excel Hell to manage a budget & pass the data back & worth to your NO-SQL back end DB's.
Bakkone
- Excel Version: 2013
Check what Gartner, Forrester and the likes has to say about performance management for different areas.
