TM1 Contributor Views are not showing updated alias value
Posted: Thu Apr 20, 2017 12:11 pm
by dharav
Hi, All
I had updated alias of an element of control dimension. I deployed the app after saving both rights and control dimension rights.
After performing above steps, i did not see the element with its new alias in contributor. It still shows old name.
FYI:
I already saved view. I removed the view from app deisgn, re applied and re deployed the application. - still no luck!!
I though there might be memory cache so i unload cube and processed feeders for that cube
Can anyone throw lights on missing concepts?
Thank You for your time
Dharav
Re: TM1 Contributor Views are not showing updated alias value
Posted: Mon Apr 24, 2017 2:33 am
by dharav
Hi, All
It is resolved. In order to update an alias of an element of control dimension, one has to also turn on alias in the system created subset of the control dimension.
Thank You
Dharav
