Hi There
Without going into the full context, I have a recharge template, where user captures the cost centre that a value must be recharges to.
This value is captured into a string element called "SYS - Cost Centre" in the Measures dimension.
So for example, user might capture the string value "CC100".
I have formulas to calculate the values in CC100, and I also need to then feed CC100.
My feeder statement is along the lines of:
['SYS - Cost Centre'] => DB(Cube1,....!Measures (This is actually position of Cost Centre dimension),............)
This does not work.
But it works fine if I change my feeder to explicitly feed for testing purposes to:
['SYS - Cost Centre'] => DB(Cube1,....'CC100' (This is actually position of Cost Centre dimension),............)
Any idea why my original feeder is not working?
I do have a FeedStrings statement.
MAny thanks!!
Chris
String Feeder Issues
Re: String Feeder Issues
You should replace !Measures with a DB() function towards that measure.
chewza
- Version: 9.5
- Excel Version: 7
Hi Wim
Works perfectly now - thanks very much!!!
Chris
Chris
