}HierarchyProperties
Does anyone know if we can use the above control cube in MDX statements in plain TM1 ? If I read this page:
https://www.ibm.com/support/knowledgece ... n0274.html
You can assign your own custom names to the hierarchy levels of the TM1® dimension by using the }HierarchyProperties control cube. The named levels you create can then be used when you externally access TM1 data with IBM® Cognos® Report Studio, MDX statements or other MDX OLAP tools. You can also assign a default member for the dimension.
Or would it mean MDX statements outside of TM1 ?
I tried syntax like:
{[Period].[Quarters]}
where Quarters was defined in the }HierarchyProperties cube, after which I ran
RefreshMdxHierarchy('Period');
in TI.
Thanks !
Re: }HierarchyProperties
Hi Wim,
I happened on your post whilst trying to do something similar today.
I managed to get something returned using this syntax
 { [<Dimension>].[<Level Name>].Members}
Unfortunately my dimension contains 6 hierarchies and each level within the hierarchies have unique names - I was hoping to use the }HierarchyProperties to name my levels more as a reference and to keep my sanity in check.
From what I see in the }HierarchyProperties cube, I would need to add additional hierarchy elements alongside hierarchy0 so that I can input my level name against the associated hierarchy for the dimensions.
The next step would be seeing if it is possible to query a level for a particular hierarchy. Right now the code above brings back elements from each of the hierarchies.
Hope the MDX helps you at any rate.
BR, George.
