Planning Analytics ( TM1 V11 ) new Service ?
ckoenig
Post by ckoenig »
can someone tell me for what i need the new Service "IBM Cognos TM1 service" which i can see if i start the TM1 Server Config ?. And also a dont understant why i have now my own Security Area where i can see Authentication/Cognos. Can i add here now my own AD or LDAP connectivity ?
Oqestions over Questions
Also i am looking for Documentations of IBM Planning Analytics ( Whats new ? )
Chris
Edward Stuart
Version: All
Excel Version: All
Re: Planning Analytics ( TM1 V11 ) new Service ?
Post by Edward Stuart »
You can find a lot of information in the FAQ Links which will help with searching for IBM links to the manuals/ documentation
http://www.tm1forum.com/viewtopic.php?f=3&t=1332
Edward Stuart wrote:You can find a lot of information in the FAQ Links which will help with searching for IBM links to the manuals/ documentation
I'll admit, though that I had neglected to update it with the links to the PA documentation downloads. That's now been rectified (for both PA1.0 and 2.0.)
Post by David Usherwood »
The 'IBM Cognos TM1' service has been around since at least the early TM1 10s. It's actually the Application Server. It's used for Applications Web and TM1 Web (and Ops Console), but not for 'normal' Perspectives use. It is based on Apache Tomcat.
ckoenig
Post by ckoenig »
to David Usherwood
are you sure if this is the Application Server. Because there is three services now and additional to Application Service there is now a new one
Not in our Planning Analytics Local environment:
PA Services.jpg (20.18 KiB) Viewed 7124 times
ckoenig
Post by ckoenig »
See my attached sreebn ;_)
Ah...
I do my best to avoid Cognos Configuration because it does hardly anything, very slowly. (Also because IBM have several versions for (eg) BI and Framework Manager and don't bother to distinguish them. :evil: )
The two services you see are (as suggested) the Application Server, and the Admin server. The clients branch on the tree relates to 'Provisioned Installs' which is for Cognos Insight - again, a quite unpopular component which we believe will fade away in the future. At present, it is most relevant for doing offline budgeting with Applications Web.
ckoenig
Post by ckoenig »
thx David
st2000
OLAP Product: TM1 (Windows) & SSAS 2014 Ent.
Version: 10.2.0 FP3
Excel Version: Excel 2013
Post by st2000 »
Here the latest documentation is available:
http://www-01.ibm.com/support/docview.w ... wg27049091
Watch for Neue Features (resp. New)
Stefan
