Does anyone use the TM1 SAP connector? This is my first time and I am experiencing some problems.
I am able to build dimensions using the SAP characteristics, but I get the following error when I try to extract data from SAP to upload into TM1.
Error: Data procedure line (0): ABAP function /SYSKOTM1/GETPACKAGE failed. SAP exception: TASK_ABORTED
Has anyone seen this?
George
Tm1 SAP Connector
Marcus Scherer
Re: Tm1 SAP Connector
late answer but maybe useful for others.
The message appeared in my case when there were restrictions applied for the SAP cube in TI. Search for "addInfoCubeRestriction(...)" in your process and if existent check if the attributes in brackets fit to the cube in question.
HTH,
Marcus
HTH,
Marcus
