9.1 API - ASP.NET / VB.NET
Posted: Mon Jul 07, 2008 3:40 pm
by kielmc
Does anyone have an example of using ASP.NET / VB.NET to connect to TM1 9.1?
Re: 9.1 API - ASP.NET / VB.NET
Posted: Tue Jul 08, 2008 7:15 am
by AnthonyT
Only via EV if that helps at all
Posted: Tue Jul 08, 2008 3:42 pm
by kielmc
we've got EV, so i'd love to see your example!
Posted: Wed Jul 09, 2008 6:23 am
by AnthonyT
Here is what I do
Using the code behind page, I create the EV object as a new Literal Control, setting a few variables along the way
Partial Class ClientCostReport
    Inherits System.Web.UI.Page
    Dim ControlPlaceHolder As PlaceHolder
    Dim litObjectTag As LiteralControl
    Dim arrObjectTag() As Byte
    Dim evServer As EV_Web_Service_DEV64.ExecutiveViewer
    Dim SessionHeader As EV_Web_Service_DEV64.SessionHeader
    Dim ReportPath As String = "/Cost Report/Client Cost Report"
    Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
        evServer = New EV_Web_Service_DEV64.ExecutiveViewer
        evServer.Url = "http://Dev_Server/EVServer/WebService.asmx"
        evServer.Credentials = System.Net.CredentialCache.DefaultCredentials
        ControlPlaceHolder = Me.FindControl("PlaceHolder1")
        ControlPlaceHolder.Controls.Clear()
        SessionHeader = evServer.CreateSessionImpersonated("Windows", "", "", "", "")
        Session("sessionID") = SessionHeader.ID
        If Session("sessionID") <> "" Then
            Dim nvc(7) As EV_Web_Service_DEV64.NameValue
            nvc(0) = New EV_Web_Service_DEV64.NameValue
            nvc(0).Name = "ControlID"
            nvc(0).Value = "EVObject"
            nvc(1) = New EV_Web_Service_DEV64.NameValue
            nvc(1).Name = "SessionID"
            nvc(1).Value = Session("sessionID")
            nvc(2) = New EV_Web_Service_DEV64.NameValue
            nvc(2).Name = "ToolBar"
            nvc(2).Value = True
            nvc(3) = New EV_Web_Service_DEV64.NameValue
            nvc(3).Name = "TabBar"
            nvc(3).Value = True
            nvc(4) = New EV_Web_Service_DEV64.NameValue
            nvc(4).Name = "Theme"
            nvc(4).Value = "Ocean"
            nvc(5) = New EV_Web_Service_DEV64.NameValue
            nvc(5).Name = "Width"
            nvc(5).Value = "85%"
            nvc(6) = New EV_Web_Service_DEV64.NameValue
            nvc(6).Name = "Height"
            nvc(6).Value = "93%"
            nvc(7) = New EV_Web_Service_DEV64.NameValue
            nvc(7).Name = "Protocol"
            nvc(7).Value = "HTTP"
            arrObjectTag = evServer.Render(ReportPath, EV_Web_Service_DEV64.RenderType.ActiveX, nvc)
            litObjectTag = New LiteralControl
            litObjectTag.Text = System.Text.Encoding.UTF8.GetString(arrObjectTag).Replace("src=", "src=""http://Dev_Server/EVServer/CreateControl.js""")
            ControlPlaceHolder.Controls.Add(litObjectTag)
        End If
    End Sub
End Class
Then, using the aspx page I use a place holder to contain the new control
<body onload = "MyLoad" >
   <asp:Table Width="100%" >
     <asp:TableRow id="T2r1">
            <asp:TableCell id="T2r1c1" Width="85%">
                <asp:PlaceHolder  ID="PlaceHolder1" runat="server">Control Not Loaded</asp:PlaceHolder>
            </asp:TableCell>
        </asp:TableRow>
    </asp:Table>
</body>
You can use the MyLoad procedure to set a few variables as well
    Sub MyLoad()
        EVObject.EnableColumnHeaders = True
        EVObject.EnableToolBar = False
        EVObject.EnableTabBar = False
        EVObject.EnableOffspreadBar = False
        EVObject.AllowSaveView = False
        EVObject.AllowDataEntry = False
        EVObject.Allow ActionAuthorisationType.ActionAuthorisationChangeDimensionLayout, False
        EVObject.Allow ActionAuthorisationType.ActionAuthorisationChangeOffspreadSelection, True
        EVObject.Allow ActionAuthorisationType.ActionAuthorisationChangeInspreadSelection, False
        EVObject.Allow ActionAuthorisationType.ActionAuthorisationFormat, False
        EVObject.Allow ActionAuthorisationType.ActionAuthorisationOptions, False
        EVObject.Allow ActionAuthorisationType.ActionAuthorisationLayout, False
        EVObject.Allow ActionAuthorisationType.ActionAuthorisationDynaSelect, False
        EVObject.Allow ActionAuthorisationType.ActionAuthorisationCalculations, False
        EVObject.Allow ActionAuthorisationType.ActionAuthorisationMemberDisplayNames, False
        EVObject.Allow ActionAuthorisationType.ActionAuthorisationPrinting, False
        EVObject.Allow ActionAuthorisationType.ActionAuthorisationActions, False
        EVObject.Allow ActionAuthorisationType.ActionAuthorisationUndo, False
        EVObject.Allow ActionAuthorisationType.ActionAuthorisationChangeNotes, False
        EVObject.Allow ActionAuthorisationType.ActionAuthorisationConnection, False
        '	#  COLOUR THE BACKGROUNDS                                            #
        EVObject.ActiveView.SetBackgroundColor BackgroundAreaType.BackgroundAreaTable, "White"
        EVObject.ActiveView.SetBackgroundColor BackgroundAreaType.BackgroundAreaRowHeaders, "White"
        EVObject.ActiveView.SetBackgroundColor BackgroundAreaType.BackgroundAreaColumnHeaders, "AliceBlue"
    End Sub
I also use it to start off a few procedures that populate drop-down boxes with the contents of TM1 subsets, and initialize a few things
Hope this helps
Anthony
