I have to do a report using Cognos BI and having cubes from TM1 as a data source.
I know i can import the cubes into BI using Framework manager and creating a package and publish this package.
Is there another way to do this without using Framework Manager? Can I somehow use the cubes by doing some changes to setting and connection, and see this cubes directly into BI?
Thank you,
TM1 as DataSource
AnonimusMax
- Excel Version: 2013
Re: TM1 as DataSource
Depends what you mean by "in BI"; if you literally just want to have TM1 cube viewers in BI you can use the URL API.
If you want to use TM1 data in report studio etc it has to be framework manager as far as I am aware.
AnonimusMax
Thank you for fast reply, I want to use Data in the report, data coming from TM1. I want to use report studio to create reports.
Can you tell me what you meant by "if you literally just want to have TM1 cube viewers in BI you can use the URL API." cube viewers?
Another question. Now we use Cognos Security for Cognos TM1. If i go to TM1 web a user can see only the countries that he has access on.
The same behavior will be also in Cognos BI? or i should implement something else?
Thank oyu
Thank oyu
mvaspal
- OLAP Product: tm1
- Version: 10 2 2 - 2.0.5
I think he meant this:
http://www-01.ibm.com/support/docview.w ... wg21637840
If you want to use tm1 cubes as data source in report studio, then yes, you should publish a package from FM.I want to use report studio to create reports.
AnonimusMax
Ok,
Thank you.
So my last question!
I have the security for dimesnions set in TM1. So when an user logs into TM1WEB he can only see the elements that he has access on.
If i use Report Studio, the behavior will be same? An user can only see the 'countries' that he has access set on TM1? Or should i do some extra configuration in FM or Cognos BI?
Thank you.
You don't have to create an FM package - BI can consume a TM1 cube as a data source.
mvaspal
- OLAP Product: tm1
Yes; you should use CAM authentication and so BI will be able to use TM1's element security. In the past there were differences how TM1 and BI were interpreting element security, not sure what is the status about that these days
few links:
http://www.tm1forum.com/viewtopic.php?t=7138
http://www-01.ibm.com/support/docview.w ... wg21616537
http://www-01.ibm.com/support/docview.w ... wg21660287
few links:
AnonimusMax
How can i consume a cube as data source withoupackage? I want to create reports in report studioDavid Usherwood wrote:You don't have to create an FM package - BI can consume a TM1 cube as a data source.
