Drill Through to ODBC - how to format output table?
Posted: Fri Mar 17, 2017 7:29 pm
by jcr55
Using TM1 10.2.2 FP3
In our development environment, I am working on Drill Through to show GL transactions (TM1 cube only stores GL balances).
I have a Cube that contains GL monthly balances. For cells at all N-levels, the Drill option works and returns a new window that is the result set of an SQL query which are the transactions that are for the Cell's period, account, company, etc.
The output table has all the columns the same width. Some columns are too narrow, and only the first characters of the Journal Entry Description are shown. Is there any way in the TI Drill Process to set column width?
Re: Drill Through to ODBC - how to format output table?
Posted: Sat Mar 18, 2017 9:26 am
by Wim Gielis
Not sure it's possible. Here is the link to another topic on how to work around shortcomings of the drill-through: http://www.tm1forum.com/viewtopic.php?f=3&t=12375
Posted: Sat Mar 18, 2017 10:31 am
by paulsimon
You don't say whether you want this to work in Excel or TM1 Web?
If it is Excel, then search this forum. I posted a way in the past to make VBA trigger the drill thru, and then you can use VBA to format the result.
In TM1 Web it is more difficult. However, what you can do, is, instead of just using a SELECT statement, you can write a SQL Stored Procedure and do some formatting within that to affect the column width, and in particular the headings. So long as the last statement in the SQL Server Stored Procedure is a SELECT that will return the formatted data, TM1 will still be happy.
Posted: Mon Mar 20, 2017 2:40 pm
by jcr55
Wim Gielis wrote:Not sure it's possible. Here is the link to another topic on how to work around shortcomings of the drill-through: http://www.tm1forum.com/viewtopic.php?f=3&t=12375
Yes, I have read through that topic. I do have an ORDER BY in the SQL, so the rows do come back in the correct sequence.
Just trying to see if there is a way to format the column widths of the drill through results grid.
Using TM1 Cube Viewer (via Perspectives), and also a TM1 Excel DBRW report.
We do not use TM1 Web at all.
