Admin Access via Starup Chore
mnaithan
Post by mnaithan »
Hello, in Development environment we have list of developers which will be added them to TM1 and assign Admin access when we will do reverse migration (Prod-->DEv), I have created a Startup chore that will read client id from file and add them, the issue I am facing with Startup chore is that its not working in single Server restart and I had to restart Server 2 times , the Security Check for TI is checked , really appreciate any feedback on this, thanks
Edward Stuart
Version: All
Excel Version: All
Re: Admin Access via Starup Chore
Post by Edward Stuart »
It would be worth posting the code so the issue could be identified easier.
If you need to restart the server twice, what do you think is happening? Dimension Updates only occur at a certain point in the process and can cause issues where you are inserting elements and attaching data to these elements, these usually get resolved by running the process twice but it is not clean.
Are you using "AddClient" or "DimensionElementInsert"?
mnaithan
Post by mnaithan »
Hi Edwar, I tried using both (AddClient and DimensionElementInsert) and (AssignClientToGroup and CellPutS("ADMIN",,,,), but not luck
