Status reset in TM1 applications
LeeTaylor1979
OLAP Product: IBM Cognos TM1
Post by LeeTaylor1979 »
Within TM1 applications is it only Admin that can reset the state of all nodes to available ?
I have a couple of users who would like to be able to action this themselves.
Thanks in advance.
mvaspal
OLAP Product: tm1
Version: 10 2 2 - 2.0.5
Re: Status reset in TM1 applications
Post by mvaspal »
I have not used Contributor for a while but is there a reset button on the portal? Do I remember well? If so, run it, and then check in the tm1server.log which TI was executed. Then give access to that TI for the user group you wish
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
LeeTaylor1979,
Yes, by default only admin can reset applications.
You can create a process, which will reset an application using tm1 application maintenance utility
