Hi Guys,
I have a requirement where i have to access my Control Cubes and TI Process from performance modeler in TM1 web. I should get access to Cube/Cube Views so that i can input my values in to cube. After i fill in the input values into my control cubes i have to execute my TI process, once it is executed i should get notification via mail stating the process got executed successfully. please provide some inputs in achieving this.
Arvind
TM1 Web Deployment
aravind.cgns
- OLAP Product: Cognos Tm1
- Version: 10.2,11
emma
- OLAP Product: 11.2.0.3.0
- Version: 10.2.20400.80
Re: TM1 Web Deployment
you can use function CellIsUpdateable and make your ti send mail to you if CellIsUpdateable return 1 (success)
http://www.tm1forum.com/viewtopic.php?t=11815 <- how to send mail
What code did you already write?aravind.cgns wrote:Hi Guys,
Arvind
If you search the forum you will find similar topics.
aravind.cgns
- Version: 10.2,11
Thanks for the reply Wim, Can we deploy the TI Process in to TM1 Web?? I have a requirement where i need to Execute TI process from TM1 Web.
Arvind
Arvind
You would use an action button then.
Again, please browse the forum and read the product documentation because this is elementary.
babytiger
- OLAP Product: Cognos TM1, EP, Analyst
- Excel Version: 2013
This doesn't make sense. They both are clients of TM1, and I don't think they walk to each.aravind.cgns wrote:I have a requirement where i have to access my Control Cubes and TI Process from performance modeler in TM1 web.
MK
Slightly adjusted:
As Wim says, this is TM1 developer 101 - Control Cube slice on a worksheet, add an Action Button to run the TI, save in an applications folder, open in TM1 Web.aravind.cgns wrote:
I have a requirement where i have to access my Control Cubes and TI Process created in performance modeler in TM1 web.
aravind.cgns
- Version: 10.2,11
Thanks Wim, Thanks David,
I have created an Application which uses my cube views and i have created a websheet with action button which calls the TI process and deployed the application. It worked well.
Thank You All Guys
Arvind
Thank You All Guys
Arvind
