Cube xxxx is used in another applicaation. xx controll dimension is required for a shared cube
Posted: Fri Feb 03, 2017 9:42 am
by ckoenig
i have a question to all of you. I have copied a Database from one TM1 Server to another. Then i opened TM1 Application/Performance Modeler based on this Database. Next step was to create an application. After i published the new application i got the message:
Cube xxxx is used in another applicaation. xx controll dimension is required for a shared cube.
How i can fix this error??
I found in internet follwoing Solution but this one deosent work. Still the same error.
https://www.simpson-associates.co.uk/bl ... -deployed/
thx
Chris
