Unable to Connect to New Server
Posted: Tue Jan 31, 2017 9:31 pm
I've trawled the archives and see some references to this issue, but none with a concrete resolution. I'm getting ready to rebuild my database from scratch (we're completely changing our chart of accounts, kill me now). I started on my dev server by spinning down the instance and deleting all of the database and log files. I restarted the instance and it recreated the base files normally. I can connect locally using the default credentials.
The problem: I cannot connect remotely.
Other things I have done:
Matt
- If I use the local admin server, a remote Perspectives client can't see the server at all.
- If I use my production admin server, I can see the server but if I double-click it I get an hourglass for a few seconds. Then it returns to the regular pointer with no open server.
- If add IPAddress=T or IPAddress=[theActualAddress] to the cfg file, I can get to a login prompt but the following error after I press OK: "Specified server not found."
- Uninstall (and delete all registry keys) and reinstall TM1 with 10.2.2 FP6 and redo the manual SSL certificate server-side edits to use v2.
- Delete and re-register the SSL certificates per a Technote.
- Disable all network connections except the single one in use, disable IPv6, confirm only one IP address is assigned via ipconfig.
- Confirm that Windows Firewall is disabled on both machines.
- Confirm that virus/malware scanner did not block connect attempts to any TM1 ports.
- Confirm that no other TM1 servers are running on this server to complete for ports.
Matt
