TM1 10.2.2 integration with Cognos Analytics 11.0.5 and SSO
Posted: Wed Jan 11, 2017 8:27 pm
Hi everyone,
You've all given me lots of great advice over the years reading your posts, but first time posting.
Server 1: Cognos Analytics 11.0.5 installed with optional gateway. IIS installed and this documentation followed to set up CA with IIS and SSO: https://www.ibm.com/support/knowledgece ... y_iis.html
This documentation requires IIS rewrite rules that redirect to the bi directory under webcontent.
Server 2: TM1 10.2.2 FP6. Followed the typical integration documentation: http://www.ibm.com/support/knowledgecen ... g_tm1_cont
When navigating to http://server2:9510/pmpsvc, after authenticating to BI, there are issues in being directed back to the TM1 applications. If the TM1 Application Configuration is set to http://server1:80/ibmcognos/bi/v1/disp for the BI URL, because of the redirect, it looks for planning.html in the webcontent/bi directory, where it does not exist. If the TM1 Application Configuration is set to http://server1:9300/bi/v1/disp, planning.html is found (in the webcontent dir), but the skins are being looked for in the bi directory (again, because of the redirect), where they do not exist. Ultimately, the redirects configured within IIS following the above documentation do not play well with TM1 integration. There is currently an open IBM support case attempting to resolve this, but at this point, they have determined this is not documented and not straightforward to configure, so it'll take some time for them to test and document a recommended configuration.
My question is this: does anyone have a TM1 installation integrated with Cognos Analytics that is using single sign-on? How do you have it configured?
Please let me know if you have any other questions about the configuration or would like to know more about what has been attempted in troubleshooting this.
Thanks, Erin
Thanks, Erin
