TM1 DBRW not displaying values after update
Posted: Mon Jan 09, 2017 3:32 pm
I have the following problem:
I log into TM1WEB. I run a process that is updating a dimension, and after that is doing some calculation. So let s say that in this dimension I insert a new Element X.
If after the update I open a report with X selected, the values from the cube for element X are not displayed.
I use a active form to bring the values into the report and the first column of the report that is using TM1RPTROW is displayed but the next ones that are using DBRW are empty.
IF I close TM1WEB and reopen it, all is working as expected and the report is showing the values. This behavior is happening with admin access.
Thank you
Thank you
