Protect and Copy
Posted: Thu May 15, 2008 8:03 am
Here is a bit of VBA code that does a similar job to the TM1 copy module that was posted on the old forum a while back by Dan Bernatchez of Revelwood.
It uses the format style that PALO uses for its Paste Data function to determine the protected area so it's a bit simpler in operation (you don't have to set protection like in the TM1 implementation). It also disables as much cut / copy / delete stuff for the open workbook as I could make it do.
I also has a copy routine that allows you to copy data over PALO.DATA cells.
Any ideas for improvements gratefully received.
