PAW - Unable to fetch data for content tree
hardstep
OLAP Product: TM1, EP, Powerplay, C8/C10
Post by hardstep »
Hi there,
When I try and access a TM1 Server via the new PAW interface I get the following error : "Unable to fetch data for content tree. Session cannot be established for Server: <ServerName>"
Does anyone know what are the correct config settings are required to enable this. The sample TM1 servers work fine - just my own TM1 server doesnt want to play :cry:
Nick
Re: PAW - Unable to fetch data for content tree
I am assuming you have allocated it a HTTPPortNumber reference in the config file? Have you checked that the port is not being used by something else?
hardstep
Post by hardstep »
Hi Declan
That was it !... I had PortNumber but not HTTPPortNumber defined and now it works.
Nick
Good stuff.
Worth noting that I think when you validate the PAW admin config it informs you of any TM1 services running that don't have HTTPPortNumber specified.
lince_1
Post by lince_1 »
I'm facing the exact same problem.
I've set-up 2 instances, the first one having an HttpPortNumber, and the second one has the parameter commented.
When validating the settings in the PAW admin screen, all good for the first one, and I can see the message "Warning -- no HTTPPortNumber specified in tm1s.cfg" for the second one.
Once in the workspace:
- when clicking on the name of the second instance, it shows the message "unable to fetch data for content tree.." straight away, as expected.
- when clicking on the name of the first instance, it "thinks" for a while and end-up displaying the message as well.
Does anybody have another idea of what could cause this message ?
Celine
dr.nybble
Excel Version: Excel 2007
Post by dr.nybble »
Is the IP address reported in the Administration Tool for that TM1 Server correct?
If you are using TM1 authentication, is the username/password good for that TM1 Server?
You can look in the log/prism-platform logs to see if there is further detailed information.
CathyBoots
OLAP Product: Tm1
Excel Version: Prof Plus 2013
Post by CathyBoots »
Hi All
I'm having the same problem as well!
It is a single server and it was working before Christmas!! I've tried about 7 different HTTP ports and I don't know what I need to do to get it working again.
The admin tool is happy that all the urls are valid.
Cathy
lince_1
Post by lince_1 »
Thanks dr.nibble for your reply (btw love the username too).
The IP address in the admin tool is correct and working (I use it to access TM1Web), and all the URIs get validated by the tool.
Username/password is correct (same for both instances), I can log into both instances through architect.
Thanks for the heads-up on the log. I guess is the interesting part is:
[1/12/17 23:26:10:362 UTC] 00000085 m1serverexplorer.endpoints.serverfolders.ServerCubesEndPoint E Failed to get children for Server Cubes
com.ibm.ba.pm.harmony.common.tm1.TM1RestException: org.apache.http.conn.ConnectTimeoutException: Connect to 192.168.40.1:8881 [/192.168.40.1] failed: connect timed out
	at com.ibm.ba.pm.harmony.common.tm1.HttpTM1ServerSession.execRESTImpl(HttpTM1ServerSession.java:392)
	at com.ibm.ba.pm.harmony.common.tm1.TM1ServerSession.executeREST(TM1ServerSession.java:197)
Just checked again and 192.168.40.1 is the IP address of the host of the VM, so not sure why the connection fails, but that's at least a direction I can investigate now:
Ethernet adapter VirtualBox Host-Only Network:
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . : fe80::119b:6981:9741:262d%3
IPv4 Address. . . . . . . . . . . : 192.168.40.1
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
dr.nybble
Post by dr.nybble »
If you put this address into your browser on the VM does it work?
http://192.168.40.1:8881/api/v1/$metadata
(or https if you have SSL enabled for the TM1 Server)
I assume your TM1 servers are running on the same system where PAW is installed.
192.168.40.1 is the address of the host on the VirtualBox Host-Only Network Adapter.
