Anyone encountered this error below when accessing Ops Console? Basically, this error pops up after I update the expired SSL certificates on my customer's server which is using version 10.2.2 FP4. I still can access TM1 Web and PM Hub Admin page normally.
Here are the details. I had tried few fix pack versions on my vbox by following the IBM technote.
(1) 10.2.2 FP4
Before SSL cert update: Able to access Ops Console.
After SSL cert update: HTTP Status 500 error.
Steps on performing SSL cert update: http://www-01.ibm.com/support/docview.w ... wg21991546
(2) 10.2.2 FP5
After SSL cert update: Able to access Ops Console.
Steps on performing SSL cert update: http://www-01.ibm.com/support/docview.w ... wg21991545
(3) 10.2.2 FP6 IF1
For test cases (1) and (3), If I revert back / undo the SSL cert update steps, I am able to access Ops Console again. What is the real thing that gives problem to Ops Console after the SSL cert update?
