Sorting hierarchy by an attribute
Posted: Wed Dec 07, 2016 10:04 am
by missspeedy23
Before I created a hierarchy in my dimension the MDX to sort by attribute worked perfectly. I have since created a structure in the dimension and the sort is now being applied to each area of the hierarchy individually. What I need to be able to do is show only the leaf level elements and then sort those by the attribute (so in effect what it did before the hierarchy was created). Is there a way to sort N level elements irresepctive of their parent?
Please see attached document demonstrating the issue.
Re: Sorting hierarchy by an attribute
Posted: Wed Dec 07, 2016 10:10 am
by Wim Gielis
Your screenshots do not match the explanation/code.
If you filter by level 0, how can you have consolidated elements in the subset ?
Otherwise your screenshots are misleading and it will not be easy to help you.
Posted: Wed Dec 07, 2016 10:52 am
by missspeedy23
Wim Gielis wrote:Your screenshots do not match the explanation/code.
I just showed the hierarchy screenshot just to show how it is sorting within each hierarchy rather than ignoring them.
So you can see in the first example "Advisor" has a sort order of 99 and "Admin Support" has a sort order of 0, so in the first screenshot which is the order the MDX is generating, "Advisor" should be at the bottom as 99 is the highest number and "Admin Support" should be at the top. Within the "Other parent" it is sorting in the sort order attribute correctly but it is doing it within each parent, not on the leafs as a whole.
Posted: Wed Dec 07, 2016 12:46 pm
by gtonkin
Try BASC at the end of your ORDER function instead of ASC.
Posted: Wed Dec 07, 2016 12:56 pm
by missspeedy23
gtonkin wrote:Try BASC at the end of your ORDER function instead of ASC.
Perfect! Thanks very much.
