Is it possible to update attributes of elements in a dimension from TM1Web? I have tried to use DBRA but even though it allows me to change the cell when i commit the change and rebuild the worksheet it defaults back to the previous value. When I log in to TM1Web as Admin it allows me to make the changes but if i login as a user i encounter the error. Is this a security issue?
I want to update the user to be able to update the attributes as the attribute is used in MDX to populate other reports and as they can change frequently this would be the most efficint way of updating if possible.
Update Attributes from TM1Web
Re: Update Attributes from TM1Web
Yes. You will need to give the user WRITE privileges to the }ElementAttributes_* cube.BigDave wrote:Is it possible to update attributes of elements in a dimension from TM1Web? I have tried to use DBRA but even though it allows me to change the cell when i commit the change and rebuild the worksheet it defaults back to the previous value. When I log in to TM1Web as Admin it allows me to make the changes but if i login as a user i encounter the error. Is this a security issue?
