Load from SAP BW to TM1 - Error
vicsense
Post by vicsense »
I'm trying to import a SAP BW cube to TM1 via ODBO with Turbo Integrator, the process was saved without errors, but when I execute it, I’m getting the next message:
Error: Prolog procedure line (6): Errors occurred during execution of process "CUBOTEST_0BUS_AREA", check error log file for that process for more details
Error: Prolog procedure line (8): ProcessError()
And in the Error Log is the next message:
Error: MetaData procedure line (0): Error getting MEMBERS rowset. Column restrictions: CUBE_NAME: $ZFI_C07, HIERARCHY_UNIQUE_NAME: 0BUS_AREA, LEVEL_UNIQUE_NAME: 0BUS_AREA.LEVEL00 - HRESULT: 80070057, Minor Code: 0, Source: MDrmSap.2, Description: Invalid restriction or schema rowset
Also if I try to import a dimension from SAP BW to TM1 with another TI Process, when I want to save it, TM1 looks for variables V10, V13 and so and the variables tab cannot be neither checked or edited.
I found in the old forum a similar problem, and it is said by Mike Cirillo that this is a problem of some SAP dlls version, and I want to know if some one in here could have those dlls. (http://applixforum.olapforums.com/viewP ... ykey=41404) :?:
TIA
Victor Noyola
Martin Erlmoser
OLAP Product: TM1, Cognos Express,..
Version: 9.1.4 FP1
Re: Load from SAP BW to TM1 - Error
Post by Martin Erlmoser »
take a look on the attached thing before you implement the patch ! :ugeek:
don't know exactly if its the correct one.. (and of course make a backup of the dlls)
odbo patch.zip
(486.24 KiB) Downloaded 708 times
vicsense
Post by vicsense »
Thanks Martin, I will check the files... hope it is the one I need!!
I'll let you know as soon as I've made some test with them!!
Victor Noyola
