Hi Experts,
I was wondering if any of you have encountered this issue:
- A cell is not fed anymore (after a restart of the service)
- Check the cell - NOT FED
- Check the Feeding cell using TRACE. It says that my above cell is FED
Have to Trick TM1, add a bogus line in the feeders portion of the Rules. ( Space line will not do it. Have to add a 'small' feeder line)
Save the rules (so it 'recompiles').
Check the cell. Everything is perfect again.
Stop the service, and restart. IT IS still ok.
Very puzzled.
Thanks for comments
FEEDERS issue/Bug
mnasra
- Version: 2.0
- Excel Version: EXCEL 2013
FEEDERS issue/Bug
Micheline
Micheline
- jim wood
- Version: PA 2.0.7
Re: FEEDERS issue/Bug
Is it a variable feeder? If so are you using persistent feeders?
mvaspal
- OLAP Product: tm1
- Version: 10 2 2 - 2.0.5
maybe posting the feeder statement would help here.
what happens if you refire the feeders with CubeProcessFeeders?
Also, in such cases persistent feeders are one of my first suspects, just as Jim asked; try the restart without the persistent feeders enabled (be sure there are no .feeder files when you start the service); I have seen this issue a few time in the past, just don't remember what was the reason...
EvgenyT
- Version: PAL 2.0.8
PersistentFeeders would be number one offender on my list, caused headache too many times before. Rule of thumb: Keep them off during the development at all times!
- roei61
- OLAP Product: PAX
- Version: 2.0.7
We had tge same isse with TM1 9.5
After installing FP of 9.5.2 this issue was solved.
