updating subset in TM1
pooja_11284
Post by pooja_11284 »
I want to fetch subset(all zero level elements) from a dimension into an excel sheet, which is connected to TM1. It is not an active form. I am populating a list(dropdown) using data validation in excel, the list contains elements from the dimension copied statically, but I want the list to get updated dynamically in case there are any future updations. Any ideas? Cn i use mdx in an excel sheet which is not an active form?
Re: updating subset in TM1
Easy. Read the documentation around the SUBNM formula.
