Is DimensionSortOrder only valid in Metadata?
macsir
Version: PAL 2.0.9
Post by macsir »
I tried it to put into Epilog. Although the process runs successfully, the element order is not changed. Looks like no effect.
It only works when I put it into Metadata.
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Re: Is DimensionSortOrder only valid in Metadata?
Post by BariAbdul »
Undertandably,Metadata changes wouldn't work when it get passed metadata tab.You have to either place it in prolog or metadat tab to get it work.Thanks
After certains actions in the Prolog tab, that function will have no effect anymore.
Once TM1 creates a shadow copy of the dimension, it's too late so to speak.
macsir
Version: PAL 2.0.9
Post by macsir »
Thanks, guys.
