DatasourceNameonServer
Posted: Wed Jul 22, 2009 6:14 am
I'm trying trying to find out whether or not I can feed a parameter into a TI process which will channge the cube view that I am using as a datasource
I know that I can do this if my datasource is an ASCII file by adding DatasourceNameForServer='\\servername\ExampleFileName.txt' to the prolog tab of a process
I have a process that I want to run and in some cases I want it to use a cube view from one cube and in other cases the cube view from another cube. Both cubes have the same structure and I am creating the view within the prolog tab also
This process runs using parameters from a cube which will dictate which datasource eg:
Parameter sSource = 'Cube1';
I've built the process using a view that already exists on Cube1 and then created a section within the prolog to create this view and a section in the epilog which then deletes it. This all works fine as long as I keep the source as Cube1
I've now added into the prolog:
DatasourceNameForServer = sSource | '->z AOL';
where sSource is now Cube2
I get the following error: (z AOL is the viewname which I am using for both cubes)
Error: Prolog procedure line (0): Unable to open data source "sSource->z AOL"
This error implies to me that it is actually changing the datasource at some point but is then failing to read the view. I feel like I'm half way there but can't get any further
The same error occurs if I feed the parameter sSource with Cube1 as well
Has anyone got any ideas?
Many thanks
Sarah Horsted
Many thanks
Sarah Horsted
