Hi there,
I'm facing a model where a list of cubes is set to "DemandLoad" = "YES". Nevertheless, all these cubes are loaded when the server is restarted. How can I make the cubes keep out of the memory?
Versions: TM1 10.1
Cubes include Rules
PersistentFeeders=T
Thanks in advance!
Mark
Cube is loaded although "DemandLoad" = "YES"
Re: Cube is loaded although "DemandLoad" = "YES"
From your post it looks as if you have rules and/or feeders referring to the cubes you don't want to load. This won't work as there will be other cubes which need that content, so the cubes need to be loaded. Is that the case?
- Version: PA 2
- Excel Version: office 365
the rules and feeders in the cube do not refer to other cubes: Nor do other cube-rules get data from the cube nor does the cube's feeders refer to other cubes.
Apologies, just found this:
http://www.tm1forum.com/viewtopic.php?t=2943
suggests that even rules/feeders internal to the cube will cause it to load. Probably not what you wanted to hear
- Version: PA 2
Thank you very much - although you're right: that's not what I wanted to hear
Mark
Mark
