TM1 Go to Another Websheet
Posted: Fri Sep 09, 2016 10:21 am
by Mark RMBC
I am using TM1 10.1.1
I am building a staff budget setting model in TM1 and am building the end user views via websheets (active forms).
When moving from one websheet to another I have set it so the calculations are none, both when moving from and to a websheet. I.e. in the action button I set calculations to none.
I have also set all sheets to manual calculation and have set the the TM1REBUILDOPTION to 0.
Here is the issue:
I log onto the web, which brings up the main menu screen and I navigate via an action button to a sheet. Then I change a value but do not press the recalculate action button. So the value is green in colour.
Then when navigate away from the sheet via an action button without pressing the recalculate button it still updates the values.
I would have expected that because of the settings outlined above the values would not have been updated?
thanks in advance for your assistance.
Mark.
Re: TM1 Go to Another Websheet
Posted: Fri Sep 09, 2016 12:21 pm
by jim wood
Moved to the correct forum.
Posted: Fri Sep 09, 2016 2:11 pm
by ellissj3
Have you checked the TM1 Web configuration for the setting that governs the sheets calculating on activation?
add value="true" key="RecalcOnActivate"
Posted: Wed Sep 21, 2016 2:23 pm
by Mark RMBC
Apologies for the delay in replying. I had assumed that because my question was on hold until the admin had verified it I would receive email notification if my post was accepted!
So I assumed it hadn't been accepted! On the off chance I had a look and here it is!
Anyway, I will look into your suggestion (big thanks for that) and post back when I have updated TM1 Web configuration.
Mark
