I am having an issue with Performance Modeler setting Weighted Average to a Consolidated level on a dimension (pic attached). we are using TM1 10.2.2.
When I tried to set "weighted average" at consolidated level, it errors "Items Not recognised". This is a built-in function and I have no choice on setting items for the calculation. other calculations where I used existing items (Margin %= Margin /Sales) have no issue. Has anyone run into this? Please share correcting the error or how it has to be used?
Luther.
Issue with Performance Modeler setting Weighted Average to a Consolidated level
LutherPaul
- PerformanceModeller - Consolidated Level-Weighted Average-Error.JPG (92.18 KiB) Viewed 5057 times
Walker86
- Excel Version: Excel 2013 64 bit
Re: Issue with Performance Modeler setting Weighted Average to a Consolidated level
Might be a silly question but have you dragged elements into the formula?
Nidhi
- Excel Version: 2013
You have to drag values for (Total product of value and weight) and Weight
Create one more element or variable
V1= Value * Weight
Weighted Average = V1/Weight
It will work!!!!
V1= Value * Weight
It will work!!!!
LutherPaul
Thanks Nidhi. I will check.
