TM1 Perspectives
ravi07598
Excel Version: 10
TM1 Perspectives
Post by ravi07598 »
will there be impact on TM1 perspective if the IP address needs to be changed for the servers ?
Re: TM1 Perspectives
Only that you will need to change the admin host so that the client points to the new location
qml
Excel Version: 2007 - 2016
Post by qml »
Welcome to the forum.
You would greatly benefit from reading the guidelines before asking questions. That way you will know how to ask a good question that can be answered to your full satisfaction.
ravi07598 wrote:will there be impact on TM1 perspective if the IP address needs to be changed for the servers ?
In the case of your specific question the only possible answer right now is "it depends" because you did not provide enough information. The Admin Host reference in Perspectives can be either a server name or an IP address, and it would be essential to know which convention is used in your organisation. It's possible that nothing will need to change, but it's also possible that it might. There are also some configuration settings you may need to change on the server side, depending on your specific setup (e.g. which components are in use, what your tm1s.cfg files look like).
Kamil Arendt
ravi07598
Excel Version: 10
Post by ravi07598 »
Steve Rowe wrote:Only that you will need to change the admin host so that the client points to the new location
Thank you Steve Rowe
ravi07598
Excel Version: 10
Post by ravi07598 »
qml wrote:Welcome to the forum.
Thank you qml will follow the guide lines .
we are using Admin Host name for TM1 perspectives configuration .
version of TM1 is 10.2.2
just want to know if the IP address of the TM1 server is changed what are the components will affect and what are the changes we need to do to run all TM1 Clients
