TM1 Applications Automation maintenance utility
Posted: Mon Aug 01, 2016 2:18 pm
by dbajaj79
Hello All,
I am stuck at using the Tm1 applications maintenance utility. I am running this below code in Command Prompt but gettind the Exit Code = 200 Error.
Can anyone please help me out with this as why it's causing it.
"C:\Program Files\ibm\cognos\tm1_64\webapps\pmpsvc\WEB-INF\tools\app_maintenance.bat" -serviceurl "http://xxxxx:9510/pmpsvc/" -username xxxx -pwd xxxx -CAMNamespace xxxxx -applicationid xxxxx -op refreshrights
Starting Tm1 Application Tool
An Exception occured during operation execute :<404> notfound
ExitCode=200
Thanks for all the help.
Best,
Sunny
Re: TM1 Applications Automation maintenance utility
Posted: Fri Aug 05, 2016 3:35 pm
by dbajaj79
Anyone with input regarding this please!!
Posted: Fri Aug 05, 2016 4:10 pm
by qml
Why don't you raise a PMR with IBM for this? The forum is a great resource, but even all the most brilliant and helpful people here don't know all answers to all questions and sometimes you have to go and ask the vendor.
