MDX- Filter By Index
roei61
OLAP Product: PAX
Version: 2.0.7
Post by roei61 »
Hi Experts,
i'm looking for MDX that will filter all the 0 level elements that their index is greater than the index of other element in the dimension.
Does someone has a good idea how to do it?
Re: MDX- Filter By Index
I'm pretty sure that MDX can't see the Index of an element so I think you would need to publish the Index to a cube using a rule or TI and then test against this which should be fairly straight forward with the help of the MDX Primer.
roei61 wrote:Hi Experts,
I haven't ever had a requirement exactly like this. Typically outside of the special case of time dimensions the index of elements is irrelevant for modeling in TM1.
But I imagine with the functions, Head, Tail & Lag that you should be able to knock up some MDX that would achieve this given the input of the element name to return all members either before or after.
