How to add all the Dimensions under the Cell Security Cube
Example:
Cube a
Dim1
Dim2
Dim3
Only this is appearing presently:
}Cell Security Cube a
-Dimensions
+Dim1
+}Groups
Rule:
want it to appear as
-Dimensions
+Dim1
+Dim2
+Dim3
+}Groups
Rule: Rule to be added for Dim3 to be 'WRITE' mode
Thanks in advance
All Dimensions in Cell Security
Re: All Dimensions in Cell Security
That should be the result if you right click a cube, go to the security and create a cell security cube. It's only when you use the function CellSecurityCubeCreate in TI that you are able to specify less dimensions in that cube.
BariAbdul
- Version: PAW 2.0.8
- Excel Version: 2019
Bit more info on the CellSecurityCubeCreate in the below thread:
http://www.tm1forum.com/viewtopic.php?t=3510 Thanks
niharika
- Version: 10.2
- Excel Version: 2013
Thank you Guys,
That Cell Security was created with just one Dimension, Because, I created the Performance Modeler Application first with Approval Hierarchy-which generated }Cell Security of any cube default, So i Destroyed all the Cell Security Cubes First and then Re-created them again : manually and then went into Performance Modeler Application
Thanks for the above Info's and links
Nik
Nik
