TM1: compare all dimension elements against variable
Posted: Thu Jul 07, 2016 10:47 pm
Hello everyone,
I am new to TM1, I have no background whatsoever in IT, and I apologize in advance for the length of this post.
I am trying to tweak an otherwise functional TI process that uses a Text Datasource to upload financial data in a cube.
My problem is with a variable of the process; let’s call it ‘Account’.
Here is the issue: when the balance of an account goes to 0, that account will be totally absent from the source files generated (the amounts are Year-To-Date).
Thus, TM1 is not being fed the information that the balance is now 0, and the prior period balance erroneously carries forward.
There is already coding in place in the Metadata tab to add new elements to the dimension based on the source file:
IF ( DIMIX (‘Accounts Dimension’ , ‘Account’ ) = 0 );
DIMENSIONELEMENTINSERT(‘Accounts Dimension’, '',’Account’,'N');
DIMENSIONELEMENTCOMPONENTADD(‘Accounts Dimension’, '',’Account’,'1');
ENDIF;
I mention this because I am now trying to do kind of the opposite.
My goal is to come up with a code that does the following:
If any dimension element = found in source file, ‘Amount’ is uploaded from source file
If any dimension element = NOT found in source file, ‘Amount’ = 0
I added the following to the Data tab. It's the closest I got to a solution.
IF(DIMNM(‘Accounts Dimension’, DIMIX(‘Accounts Dimension’,’Account’))@=’Account’);
‘Amount’=’YTD balance’;
ELSE;
‘Amount’=0;
ENDIF;
This logic is flawed because the element component in the DIMIX function is limited to only accounts that are in the source file.
Hence, dimension elements not included in the source file are not subject to this function, which defeats the very purpose of what I am trying to do.
What I need is a way to compare ALL dimension elements against the ‘Account’ variable.
I tried multiple math tricks to make up for it without success.
Eg:
'Element': Some kind of subset of all dimension elements ??
IF(DIMNM('Accounts Dimension', DIMIX(‘Accounts Dimension’, 'Element'))@=’Account’);
Or some more desperate attempts thinking I could create a variable equal to any number using RAND:
'Index'= 'RAND()*2+RAND()*3+RAND()*4' |'RAND()*2+RAND()*3+RAND()*4' |'RAND()*2+RAND()*3+RAND()*4';
IF(DIMNM(‘Accounts Dimension’, 'Index')@=’Account’);
Is there a way do this?
Hoping that my explanations were clear.
Thanks in advance
ENDIF;
ELSE;
‘Amount’=0;
ENDIF;
Eg:
Thanks in advance
