Deleted calculated element in measure still showing
mnasra
Version: 2.0
Excel Version: EXCEL 2013
Post by mnasra »
Hello experts,
I have the weirdest 'bug' i have ever seen with my 6 years with TM1.
I had an element in a measure that I calculated via rule.
I changed the element name, I change the rules and I deleted the element.
I opened an old 'perspectives' report where this element is still mentioned. I would expect a KEYERR message, but no: TM1 calculates it perfectly using the new data.
No: I dont have an ALIAS
no: i dont have persistent Feeders on
Yes: I stopped the service and restarted it many times.
in tm1 architect I dont see it obviously, but in Perspectives, even if I open a new one and write down a DBRW command, it shows with a calculation!!!
Micheline
Re: Deleted calculated element in measure still showing
Do you perhaps have a subset on the measures dimension having the same name? There's an undocumented feature in TM1 whereas you can supply a subset name to a DBRW and it will treat it like a consolidated element and do the consolidation on the fly. This could be your issue.
