Border every 7th row
AlvinPresley
OLAP Product: IBM Cognos Tm1
Version: TM1 Web
Post by AlvinPresley »
Is there anyway in which we can put a different border for every 7th row and a different border for the first 6 rows? Every 7 rows have the same rptrow value!
I've tried to use the conditional formatting in the format section but that doesnt seem to work. May be because i have another condition already on it for changing it to % or numeric value?
kindly Help!
Re: Border every 7th row
AlvinPresley wrote:I've tried to use the conditional formatting in the format section but that doesnt seem to work.
And what exactly did you try?
ardi
OLAP Product: tm1, cognos bi
Post by ardi »
AlvinPresley wrote:Hi,
kindly Help!
You can do this in the Active Form Format Area. Add a row in your format area, give it the ID you want ( for example N7 ) and apply the formatting you want for that row
Then in the first column of your Data Range, write some formula ( you can use Excel Formulas or TM1 Formulas ) that will return "N7" for the rows you want to apply that specific formatting
Ardian Alikaj
deepakjain2020
Version: 9.5.2; 10.2.2
Post by deepakjain2020 »
What Ardian said should work for sure.
Assuming you can figure out where you went wrong with your conditional formatting, the easiest is to add a condition like:
=MOD(ROW(),7)=0
You would need to on which row you want the change and change the 0 in the code above accordingly.
BR, George.
AlvinPresley
Version: TM1 Web
Hello People!
Thank you for your suggestions! I had to change the entire formatting area to set things right! Thanks to Ardi..It did work..that is what i did..I was just looking for a workaround though. Anyways, figured that this way was much simpler and a straight forward approach! Thanks again!
