Dynamic drop down list on TM1 web
wangspock
Post by wangspock »
I just start to learn TM1 Web. I need to create a input sheet that has a dynamic drop down list base on the user credential. I am using Excel data validation. It was working fine in Excel but get a #CIRC! on the list of selection when I move it to WEB. I try several different ways as I discover some of the Excel function does not supported in WEB. Below are the names contain formula. Data Validation Selection = List_BU_User
List_BU_User=INDEX(TB_BU_User,1,Sub_TB_Column_Numb) : INDEX(TB_BU_User,COUNTIF(Sub_TB_Column,"?*"),Sub_TB_Column_Numb)
List_Column_Numb=OFFSET(BU_Pick!$A$7,0,0,COUNTA(BU_Pick!$A$7:$A$201),1)
List_Users=OFFSET(BU_Pick!$B$7,0,0,COUNTA(BU_Pick!$B$7:$B$201),1)
Sub_TB_Column=INDEX(TB_BU_User,,Sub_TB_Column_Numb)
Sub_TB_Column_Numb=VLOOKUP(User_TM1,TB_Vlook_Column_Numb,2,FALSE)
TB_Vlook_Column_Numb=OFFSET(BU_Pick!$A$7,0,0,COUNTA(BU_Pick!$A$7:$B$201),2)
TB_BU_User : Excel table
Any help is greatly appreciated
Version: PA 2.0.7
Re: Dynamic drop down list on TM1 web
Post by jim wood »
Why don't you build a pick list cube and use rules to build the pick lists? That way it'll work in any interface.
Why not store the drop-down data in a cube and make it a picklist? If you use the }Clients dimension in the cube you will then be able to pull back the appropriate selections based on their login ID.
wangspock
Post by wangspock »
Person who manage TM1 does not want to create any additional object. I can only work with what I have.
wangspock wrote:Person who manage TM1 does not want to create any additional object. I can only work with what I have.
In that case I suggest you consult the TM1Web documentation. It has a list of supported Excel functions. As long as you stay within those boundaries then whatever you come up with in Excel will work in TM1Web.
That is like saying "person who manage TM1 does not actually want this requirement met"
The best way (by far) to solve the requirement is to use a picklist cube. It is completely irrelevant that this another TM1 object.
wangspock
Post by wangspock »
Finally figure it out. Lookup table does not work on TM1 Web.
EvgenyT
Version: PAL 2.0.8
Post by EvgenyT »
Or more like saying person who manages TM1 does not know what is he / she doing...
I would strongly advocate to keep bare minimum in Excel and shift all the "funky" logic to TM1 where it is handled much better.
Plus creating a picklist cube is not really creating an additional object per se, its a control object.
