Assign the value to an element according to the picklist value.
Prajan_cyber
OLAP Product: tm1
Post by Prajan_cyber »
Please help,New to TM1
cube 'salaryassump' has below dimensions
Grade Salary
Grade1 2000
Grade2 3000
Cube Salarycal
Have a dimension element called "grade" with picklist static:grade1,grade2,grade3 and another dimension element is salary.
When grade1 is selected from the picklist ,would like to populate salary with 2000 from salaryassump cube.
Getting an error message.
skipcheck;
['Salary'] = N:
if (attrs('payroll',!grade,'picklist') @= 'Grade1',
DB('SalaryAssump','Grade1','Salary'));
Thanks in advance.
Re: Assign the value to an element according to the picklist value.
skipcheck;
['Salary']= N:
DB('SalaryAssump',DB('Salarycal',!payroll,'grade'),'Salary');
Prajan_cyber
OLAP Product: tm1
Thanks Wim for your reply.
Now the error has gone .But salary value is not populating,it just shows as '0'.
Prajan_cyber wrote:Thanks Wim for your reply.
To solve that, we have the "Trace calculation" option in the cube viewer.
Also, pay attention to feeders, if applicable.
Wim
Assuming the code you posted was an "approximation" of the actual code, it's almost impossible to help someone resolve their problems without full disclosure. If you can post the complete dimensionality of both cubes and the actual code that you've written it should be easy to fix.
Prajan_cyber
OLAP Product: tm1
Cube 'salaryassump' has below dimensions
Grade Salary
Grade1 2000
Grade2 3000
Cube Salarycal has below dimensions
Department
Payroll : Headcount ,Salary,Benefits,Bonus,401k,Grade
Year
In payroll 6 elements ,and one of the element is Grade and has a picklist :static:grade1:grade2
When I select grade1 the salary should get the value from the 'salaryassump' cube as '2000' and populate into the cube.
Please let me know how to achieve this.
I am doing this as a learning exercise
Any help will be appreciated.
ardi
OLAP Product: tm1, cognos bi
Post by ardi »
If I understant it correctly, your Payroll Dimension is your Measures dimension ( correct? ). Normally Measures dimension is the last dimension in the cube.
But my other problem with that cube design, it looks like you can have only One Grade for One Department / Year combination. Maybe this is what you want, so in that case, the Rule Wim wrote should give you the result but you need to feed that cell or remove the SKIPCHECK if this is such a dense cube with only 3 dimensions
Ardian Alikaj
Please post a screenshot from Server Explorer of each cube, expanded. By this I mean clicking the plus sign next to each cube so we can see the dimension names and in what order they appear in the cubes.
Prajan_cyber
OLAP Product: tm1
changed the dimensions to 2 to make it easier,sorry unable to paste the screenshot.
Cube SalaryAssumptions same order as server explorer
Grades : Grade1,Grade2,Grade3
Salary : 2000,3000,4000
Cube SalaryCal same order as server explorer
Year
Payroll: Headcount,Salary,Benefits,Bonus,401k,Grade,Dept
Grade has a picklist value like Grade1,Grade2,Grade3
When I pick Grade1 the salary cell has to populate as 2000 , the value from the Salaryassumptions cube.That's all.
Trying to learn TM1.
Thanks in advance.
What are the dimensions of the Salaryassumptions cube ?
I hope you don't have a dimension where you have the salary amounts as elements...
