TM1 API string limit
Posted: Tue May 17, 2016 9:16 pm
Hello all,
While creating a TI process from inside Excel VBA (I'm almost there !), I run into an issue of I think a String limit of 1,024 characters.
For example, if we put code in the Prolog of a TI process, after 1,024 characters (vbCrLf characters added, which is 2 characters every time) we find an extra CRLF character.
In itself, this isn't too much of a problem, we can just delete the few extra CRLF characters and we're done.
But when the extra CRLF breaks a commentary line in 2 pieces, the process won't save since syntaxically there is an error.
For example, have a look at the line with "SubsetCreateByMDX" for the dimension }Processes where effectively TM1FilterByLevel has been chopped off:
Here is the relevant portion of the code (without error handling, just the code):
sCode_Prolog is a String variable with each time the character § to mark a new line.
Does this limit of 1,024 characters pertain to the function TM1ObjectPropertySet ? Or Tm1ValString ?
Any pointers towards a solution of avoiding the extra CrLf character ?
Thanks a lot !
vCube = 'General_Process control' ;
vView_Tgt = 'ZZZ_tmp' | '_' | Timst( Now, '\Y\m\d\h\i\s' ) ;
vSubset_Tgt = 'ZZZ_tmp' | '_' | Timst( Now, '\Y\m\d\h\i\s' ) ;
# Turn off target cube log changes
CubeSetLogChanges( vCube, 0 );
# Custom settings to output information to a text file
DataSourceAsciiDelimiter = ';';
DataSourceAsciiQuoteCharacter = '';
# Zero Out the Target View
# Start from scratch: destroy the temporary objects
ViewDestroy( vCube, vView_Tgt );
SubsetDestroy( '}Processes', vSubset_Tgt );
SubsetDestroy( 'General_Process measures', vSubset_Tgt );
# Create a temporary view
ViewCreate( vCube, vView_Tgt );
# Limit the contents of the view
ViewExtractSkipRuleValuesSet( vCube, vView_Tgt, 1 );
ViewExtractSkipZeroesSet( vCube, vView_Tgt, 1 );
ViewExtractSkipCalcsSet( vCube, vView_Tgt, 1 );
ViewExtractSkipConsolidatedStringsSet( vCube, vView_Tgt, 1 );
# Create temporary subsets in dimensions
SubsetCreateByMDX( vSubset_Tgt, '{TM1Sort( {TM
1FilterByLevel( {TM1SubsetAll( [ }Processes ] )}, 0)}, Asc)}', '}Processes' );
SubsetCreateByMDX( vSubset_Tgt, '{TM1Sort( {TM1FilterByLevel( {TM1SubsetAll( [ General_Process measures ] )}, 0)}, Asc)}', 'General_Process measures' );
# Adding subsets to the view
ViewSubsetAssign( vCube, vView_Tgt, '}Processes', vSubset_Tgt );
ViewSubsetAssign( vCube, vView_Tgt, 'General_Process measures', vSubset_Tgt );
# Clear existing data
ViewZeroOut( vCube, vView_Tgt );
# Tidy up: destroy temporary objects
SubsetDestroy( 'General_Process measures', vSubset_Tgt );Code: Select all
'1 - PROLOG
sqCode_Prolog = Split(sCode_Prolog, "§")
CountOfLines = UBound(sqCode_Prolog) + 1
ReDim PrologLines(CountOfLines - 1)
For i = 0 To CountOfLines - 1
PrologLines(i) = sqCode_Prolog(i)
Next
ReDim lArray(CountOfLines)
hArray = TM1ValArray(hArrayPool, lArray(), CountOfLines)
For m = 0 To UBound(PrologLines)
TM1ValArraySet hArray, TM1ValString(hsPool, PrologLines(m), 0), m + 1
Next
lReturn6 = TM1ObjectPropertySet(hppPool, lReturn4, TM1ProcessPrologProcedure, hArray)sCode_Prolog is a String variable with each time the character § to mark a new line.
Thanks a lot !
