Delete a TI through TI
Posted: Fri May 13, 2016 2:22 pm
by madan314
Hello TM1 Experts,
In our PROD server , there are lot of TIs thats been created for onetime dataload ,and I would like to get rid of these at one shot , rather than manually deleting each one by one. Is there an automated way of deleting these or it has to be manual way. Please advise
Madan
Re: Delete a TI through TI
Posted: Fri May 13, 2016 2:34 pm
by Wim Gielis
The easiest, while still keeping control, is to go the Server Explorer and click on the Processes node.
Then turn on the Properties pane.
Then using Ctrl and Shift, you can select multiple processes at once, hit DEL, confirm the thing, and go the next set of processes.
When processes are used in chores (unlikely in your case though), you cannot delete these processes immediately.
Posted: Fri May 13, 2016 2:46 pm
by madan314
Thanks Wim for quick response. This is useful
