Hello Folks!
Here is the issue:
I have created an active form with two cubes. I have 5 RPT Rows , one below the other with a couple of calculations below each. I have set one format range with one Data format column and 5 data ranges for the rpt rows, one for each.I am getting the proper output in the TM1 Web.
The format seems good when view in web. But when I export it to pdf , take a snapshot or slice to excel, the format looks good for the first three RPT rows which belong to the first cube whereas the format doesnt continue to the next two RPT rows which belong to the second cube! The data is present but no format. I've read that there is an issue with the FP5 but then i get proper output for the other reports while i developed.
Kindly Help!
Cheers!
Two cubes with multiple RPT Rows and format error
AlvinPresley
- OLAP Product: IBM Cognos Tm1
- Version: TM1 Web
