MDX Primer
MDX Primer
As promised, the MDX Primer is attached.
Please note that everything in it worked in the version(s) quoted and in the model described. YMMV. If something doesn't work now, report it to Applix.
Philip Bichard
Philip Bichard
- MDX Primer.zip
- (446.2 KiB) Downloaded 2245 times
Reason: Removed stickyness as pertinent post now in "Useful Code" thread.
- Renaud MARTIAL
Re: MDX Primer
Thank you very much, Richard,
very interesting
Renaud.
very interesting
Renaud.
Guillaume Galtier
Re: MDX Primer
Great job
- bihints.com
- Version: 9.0.3
- Excel Version: 2003
Re: MDX Primer
This document should be "wikiized" ( yes it's a word, 41 hits on google
so the contents are visible on search engines and we can edit/amend it as I did on bihints.com
Ultimately the full TM1 documentation should be turned into a wiki.
I talked to some Applix managers about that but they didn't really appreciate the idea claiming docs must be accurate,
although I strongly believe crowdsourcing docs through wiki would deeply enrich these.
- Eric
- Version: 9.4
Re: MDX Primer
THIS IS .............. wait for it
Eric
Eric
- Eric
- Version: 9.4
Re: MDX Primer
AWESOME!!!!!
Eric
Eric
- garry cook
- Version: Various
- Excel Version: Various
Re: MDX Primer
Indeed. Excellent work.
Re: MDX Primer
Great work as usual Philip.
Will try MDX again and hope it does not crash the server this time
Ken
Ken
- George Regateiro
- Version: 10.1.1
- Excel Version: 2007 SP3
Re: MDX Primer
Just came across this post. This is great. Thank You.
Re: MDX Primer
I discovered the primer one year ago, and set that use I it eagerly. Thank you Philip
- Steve Rowe
Re: MDX Primer
First of all
and I sitckyed this, which I'm pretty sure isn't a word no matter what google says!
err I couldn't sitcky the doc as the forum is bugged.... Who's in charge round here??
ROFL, I would say wiki docs are likely to be more accurate....Ultimately the full TM1 documentation should be turned into a wiki.
- Martin Ryan
Re: MDX Primer
I edited the original post by Philip and made it a sticky. That seemed to do the job.
- jim wood
- Version: PA 2.0.7
Re: MDX Primer
No wonder your post count is so high!!!Eric wrote:THIS IS .............. wait for it
- Eric
- Version: 9.4
Re: MDX Primer
Who
Eric
Eric
- Eric
- Version: 9.4
Re: MDX Primer
me?
Eric
Eric
- Eric
- Version: 9.4
Re: MDX Primer
Chris Web has some good MDX stuff on his blog, he could also be a decent reference.
http://cwebbbi.spaces.live.com/?_c11_Bl ... =cat%3dMDX
Eric
Eric
- Steve Vincent
- Version: 10.2.2 FP1
Re: MDX Primer
Shame Spaces is a blocked site from here. Or not, as the case may be
Terramup
- Version: 10.1.0
Re: MDX Primer
A co-worker of mine came across an updated version of your document. Would you be willing to put it on the forum?
Re: MDX Primer
Glad everyone finds it useful after all these years. The latest version lives permanently on my website at www.pxbconsulting.com. It's easier to maintain that way, not that it's changed too much in recent times. I do get emails from readers from time to time so I know people are finding the 'real' version. I'm afraid I don't really use this forum myself. As you may know the version on bihints.com is an early draft - it was too much work to maintain, hence the current simple way of publishing it.
All the best,
Philip Bichard
All the best,
Philip Bichard
