Hi community,
how can I deactivate the automatic Recalc in TM1 Web?
Typing data in consolidated elements in TM1 causes an immediate calculation (breakback on the children). I want TM1 Web to wait with the calculation until I press the recalc button. Is this possible?
I already tried to set the paramter <add key="UseBookRecalcSetting" value="true" /> to true in TM1web_config.xml and also set formula options in Excel to manual calculation. But nothing changed.
Thank you.
Deactivate automatic Recalc in TM1 Web
Re: Deactivate automatic Recalc in TM1 Web
Horst
- Excel Version: 2013
thank you for your fast reply.
What if I've already done this? I've attached my TM1web_config.xml and Excel settings (sorry, it's in german).
I've restarted the tm1 Service and uploadet the Excel sheet into tm1 Web - but the automatic recalc is still enabled. Do you have any ideas why?
- tm1web-config.xml.png (21.41 KiB) Viewed 3609 times
- Excel.png (20.81 KiB) Viewed 3609 times
The automatic recalc associated with breakback on consolidated cells can not be changed as far as I am aware.
