Feeder issue
vovanenok
Version: 2.0.9
Feeder issue
Post by vovanenok »
Maybe I don't understand something about feeders, that's why I'm asking.
I have the measure dimension:
fin_percent is calculated using a rule:
Finally Station dimension looks like:
alloc_amount for TV and Radio is copied from TV Stations and Radio Stations consolidations by TI process (for performance optimization), so fin_amount for each station including TV and Radio elements should be always fed if there is any value for alloc_amount, consequently fin_percent should be fed as well.
However I have a problem with one TV station, for some reason when look at its fin_percent at FTE CE Group ("Cost Element" dimension consolidated element), it displays the right value: 2.91%
also when I click check feeders it shows that it's fed, but when I suppress zeroes that fin_percent disappears, so in fact it is not fed.
What am I missing here?
TeamOne Google Sheets add-on for IBM Planning Analytics
Let's connect on LinkedIn
vovanenok
Version: 2.0.9
Re: Feeder issue
Post by vovanenok »
I don't know why but I was not able to attache the 4th screen shot, attaching it here:
After zero-suppression:
Re: Feeder issue
I think you are running into trouble with C level rules and feeders.
Feeders only happen at the N level, think ticks in a box that says calculate me.
C level cells are only "fed" if at least one cell under it is fed and non-zero.
So in your first view in the second post, since there is no value under the problem cell (that I can see in the screen shot). The C level cell is not "fed" and so does not display.
Steve
vovanenok
Version: 2.0.9
Re: Feeder issue
Post by vovanenok »
Hi Steve
Thanks for you reply. This is exactly what I thought initially, but was not sure about if feeders work on C-level.
So I need that Cost Element consolidation to be calculated even there is no child elements with values.
One solution that comes to my mind is making fin_percent to be a consolidated element and having at one child element which will be feeding it
For example, I could move fin_amount under fin_percent
Does anybody have any better recommendation?
Re: Feeder issue
vovanenok wrote:Hi Steve
Unless you have a scenario where fin_percent will be calculated for actuals but input for forecast then there is absolutely no reason for this to be an N element. Rather it can be a C with fin_amount as a child which acts as a "feeder". Nothing changes to the rule other than it becomes C: and you remove the feeder as it is now redundant.
vovanenok
Version: 2.0.9
Re: Feeder issue
Post by vovanenok »
Hey lotsaram, thanks for your answer, yes this is what I've done to resolve my issue.
Please clarify if there is any case when we can use a consolidated element on the left side of feeder statement, as I found this example http://ykud.com/blog/cognos/tm1-cognos/ ... ed-feeders which shows feeding from a consolidated element, but it didn't work in my case
Re: Feeder issue
Feeders are substitute DATA. Therefore it is critical to realize feeders only exist for leaf cells. Putting C element on the left hand side of a feeder is shorthand for all ultimate N element descendants of the C element. On the right hand side the element name evaluated by !dimension are the leaves not the C element. This is important to understand.
vovanenok
Version: 2.0.9
Re: Feeder issue
Post by vovanenok »
lotsaram wrote:Feeders are substitute DATA. Therefore it is critical to realize feeders only exist for leaf cells. Putting C element on the left hand side of a feeder is shorthand for all ultimate N element descendants of the C element. On the right hand side the element name evaluated by !dimension are the leaves not the C element. This is important to understand.
hey lotsaram, thank you so much for the explanation! Now that puzzle is completely solved for me!
