Create Contributor application through TI
- tiagoblauth
- OLAP Product: TM1, Cognos BI
- Version: 10.2.1
Hi all, is there a way to create Contributor applications through TurboIntegrator or prompt command? I did an application who self create cubes, rules, views and subsets. I can do a lot of things through TI such as manage objects and contributor security, assign TI process for Commit and Submit actions, adjust Contributor hierarchy.... but I didn't found any reference to create the contributor applications itself. This is my final frontier
Bakkone
- Excel Version: 2013
Re: Create Contributor application through TI
Try publishing an application from PM or Architect and check the logs for what processes are run. Looking at the control objects there is a process called }tp_application_deploy that seems to do all sorts of things. I would dive into that one.
And there are pros here that will probably give you a better answer. But until they wake up take a look at that process.
- sachin
- OLAP Product: Transformer,SSAS, EP, TM1
- Version: 7.3 2005 10.1 10.1.1
Not sure if TM1 Application Maintenance Utility will help you. Have you had a chance to look at it? http://www.ibm.com/support/knowledgecen ... ml?lang=entiagoblauth wrote:Hi all, is there a way to create Contributor applications through TurboIntegrator or prompt command? I did an application who self create cubes, rules, views and subsets. I can do a lot of things through TI such as manage objects and contributor security, assign TI process for Commit and Submit actions, adjust Contributor hierarchy.... but I didn't found any reference to create the contributor applications itself. This is my final frontier.
It helps deploy an app but not create (at least as per the doc).
