ViewExtractSkipRuleValuesSet
PavoGa
Excel Version: 2013 PAW
Post by PavoGa »
I am needing some clarification on how this actually works because I am seeing a behavior that, while I did not expect it, actually makes sense in a way.
Here is the scenario: We have a process that copies data from one cube to a blank copy of that cube, the copy having no rules. We only want non-rule driven, non-consolidation data, so we set:
ViewExtractSkipCalcsSet(cubDLBRInputTBD, vwSource, 1);
ViewExtractSkipRuleValuesSet(cubDLBRInputTBD, vwSource, 1);
ViewExtractSkipZeroesSet(cubDLBRInputTBD, vwSource, 1);
Here is the problem. We saw some values show up in the target cube after the copy that had zeros same cells in the source cube. When we turned off the rule for the source cube, lo and behold, there were the values. Now, we know that if a value was written to a cell in a cube and a rule later comes into play for that cell, that the underlying value is retained. So here is the question: does ViewExtractSkipRuleValuesSet do nothing more than turn off the rules while the process is running? What I expected was a skipping of any rule-derived cell, not just a turning off of the rules.
If it is doing nothing more than turning off the rules, then I should expect any underlying value to copy. Seems to be that is what we are seeing.
Ty
Cleveland, TN
PavoGa
Re: ViewExtractSkipRuleValuesSet
Post by PavoGa »
Surprised this did not engender some comment. Did I miss something?
Ty
Cleveland, TN
BrianL
Version: 9.5.2 10.1 10.2 PA2
Post by BrianL »
I think there's no comment because you answered your own question. You did the test to see what the actual product behavior is and you even came up with an explanation for it.
What else are you looking for? Confirmation that TM1 is supposed to behave that way? You would have to go to IBM for that confirmation not this forum.
PavoGa
Post by PavoGa »
Actually, yes, I was looking for confirmation this behavior was expected and/or observed by others. I did not find any other references to it in my searches on the subject and, with all due respect, there are plenty of threads on this forum dealing with observed TM1 behavior that is not documented.
If I phrased my original request and questions in an incorrect manner, please forgive me.
Ty
Cleveland, TN
tiagoblauth
OLAP Product: TM1, Cognos BI
Version: 10.2.1
Post by tiagoblauth »
Hi, let's see if we are in the same page. When you create a Turbointegrator to copy values from one cube to another, TI reads cell by cell from the source view and follow you commands to copy the values to the target cube. This ViewExtractSkipRuleValuesSet function filters the rule cells in the source so TI will not go through it. It's a simple way to filter the source in the cube.
One easy way to test these functions is to right click a cube view and select "Export as test data...". There are some skip options that works in the same way as these options here.
If you want to create a backup cube and it doesn't have any rule, you should use:
ViewExtractSkipRuleValuesSet(cubDLBRInputTBD, vwSource, 0);
Good luck and please let us know if you need something else.
Overwriting values that have actually been entered into a cube, either manually or TI, by writing a rule that supercedes them does not get rid of the values stored in the cube. You just never see them because the rules engine overrides them. However, if you remove the rule they will lo and behold reappear. Is this normal or expected? I have no clue. In my opinion it should not work this way but it does. It's a shame they have never documented it.
Indeed, a simple and quick zero out method by writing a rule that we used to do in earlier versions of TM1, has vanished since some time.
babytiger
Post by babytiger »
I believe once you have the rules in place, ie. On top of stored values. Then perform a cubesavedata or a savedataall function, it will remove the stored values that are superseded by the rules.
MK
Andy Key
Version: 2.5 to PA
Excel Version: Lots
Post by Andy Key »
How these values will get exported will depend on your setting for RulesOverwriteCellsOnLoad in the config file.
Andy Key
qml
Excel Version: 2007 - 2016
Post by qml »
Well, as Andy says, there is a config parameter RulesOverwriteCellsOnLoad whose documentation explains the intended default behaviour and how to change it. It seems that by default, values in cells that have rules applied are not wiped out until the next server (re)start. This can be changed in such a way that the values are never wiped out, but it cannot be changed in such a way that the values are always wiped out right away after applying a rule.
I would personally welcome a new switch to make TM1 remove data for rule-derived cells on rule save, but it should definitely not be the default. Being able to remove all data in a cube with a rule mishap is too risky to make it the default behaviour.
Kamil Arendt
Bakkone
Post by Bakkone »
Personally I wouldn't mind.
I would love it if removal of a rule meant the last calculated value was saved as a static value. But this would then mean that any previous written value would of course have to get overwritten.
PavoGa
Post by PavoGa »
babytiger wrote:I believe once you have the rules in place, ie. On top of stored values. Then perform a cubesavedata or a savedataall function, it will remove the stored values that are superseded by the rules.
This is not consistent with what we have seen on this. The values never go away once they are there unless actions are taken to clear them out.
Ty
Cleveland, TN
qml
Post by qml »
PavoGa wrote:This is not consistent with what we have seen on this. The values never go away once they are there unless actions are taken to clear them out.
Does a server restart change anything?
Kamil Arendt
PavoGa
Post by PavoGa »
After reading the comments and the documentation on RulesOverwriteCellsOnLoad (Thank you, Andy and qml), I discussed with the other developers, one of whom worked with IBM and Applix, and we believe we are seeing this holding on to underlying cell values on rule-driven cells even through server restarts. However, the discussion has raised a couple of questions in my mind, so we'll test a couple of scenarios and see what we get.
Thanks for all the comments. This is apparently not cut and dried as it seemed.
Ty
Cleveland, TN
PavoGa
Post by PavoGa »
tiagoblauth wrote:Hi, let's see if we are in the same page. When you create a Turbointegrator to copy values from one cube to another, TI reads cell by cell from the source view and follow you commands to copy the values to the target cube. This ViewExtractSkipRuleValuesSet function filters the rule cells in the source so TI will not go through it. It's a simple way to filter the source in the cube.
But we are specifically, as stated, looking for non-rule driven cells only.
Ty
Cleveland, TN
BrianL
Post by BrianL »
I would not expect previous cell data to ever get removed if TM1 thinks there is a rule statement that applies and returns 'continue' even conditionally. I'd need to test to be certain, but it should be a pretty quick and simple test to run.
PavoGa
Post by PavoGa »
BrianL wrote:I would not expect previous cell data to ever get removed if TM1 thinks there is a rule statement that applies and returns 'continue' even conditionally. I'd need to test to be certain, but it should be a pretty quick and simple test to run.
Yes, but we are getting it even on non-conditional rules. For whatever the reason, sometimes a decision was made to change a cell to being rule-driven. If there was a value, the value is sticking. I did do some testing today including server shutdowns and restarts to confirm.
So it seems to be confirmed that ViewExtractSkipRuleValueSet simply ignores the rules for a given view, it does not actually skip over rule driven cells. I agree with tomok, my opinion is that it should not work that way, but it does and the documentation is not really clear on the point.
Thanks again.
Ty
Cleveland, TN
This really shouldn't be an issue. As a general rule you should never put rules on a previously input cell in a production environment. This should be done in development and when you promote to production the cube should be empty with the data loading in production. This propblem would have never reared its ugly head had you done it that way.
Karthik1710
Post by Karthik1710 »
Curious. I just tested it out.
Had a test cube created with 2 dimensions (Dummy_Acct, Dummy_Amount).
First entered an amount of 25000 for all accounts.
Through a rule, assigned 500 to one specific account.
Using a TI, I took the cube as source and used below:
Put in an ASCIIOUTPUT in Data.
Result: I did not see the rule over-ridden Account in the output file.
So I think the ViewExtractSkipRuleValuesSet works the way I thought it works. It simply skips reading the cells that have rules set. Is that what you are looking for?
P.S.: I am yet to check what are the config parameters set.
PavoGa
Post by PavoGa »
That is inconsistent with all of our testing and experience.
Ty
Cleveland, TN
